- Feb 17, 2021
- 466
Orderd "what I thought" to be a set of inserts for a shell mill and to my surprise only one came is it true you can use only one insert in a 3 insert shell mill holder or did the seller make a mistake???
You definitely got shorted. You can use this as an opportunity to choose quality inserts.Orderd "what I thought" to be a set of inserts for a shell mill and to my surprise only one came is it true you can use only one insert in a 3 insert shell mill holder or did the seller make a mistake???
Yes you can. It becomes an inserted fly cutter. Not the way the cutter was intended to be used though. What did the listing state?Orderd "what I thought" to be a set of inserts for a shell mill and to my surprise only one came is it true you can use only one insert in a 3 insert shell mill holder or did the seller make a mistake???
Have you revisited your order and brought the issue to the attention of the supplier?Orderd "what I thought" to be a set of inserts for a shell mill and to my surprise only one came is it true you can use only one insert in a 3 insert shell mill holder or did the seller make a mistake???
sure have.......Have you revisited your order and brought the issue to the attention of the supplier?
