Hello all.
I need to turn into a location about 14mm long with a shoulder each end that prevents me using triangular or diamond shaped inserts.
The material is Rockwell hardness of around 60 so normal tool steel won't do the job otherwise I could grind up something suitable.
Specifically it is a running surface for needle rollers and the shoulder at each end is to contain the rollers.
What can I use please?
What about a carbide parting insert?
Thanks
Doug
Thanks
Doug
