Refractory Brick
I dunked the bricks in water when shaping and mortaring them. It keeps the dust down and keeps the mortar from drying out too fast.
I used a minimum amount of mortar between the bricks to get a seal. It is "very" important to do an oven break-in when adding water
to the bricks. I will cover this later.
Controls
Almost every article on homemade heat treat furnaces on the web mentions Auberins and Budget Casting Supply as the go-to places for the heating equipment.
1. 120 Vac Kanthal Heating Element - 2300 °F Max #7101 (Qty=2)
2. Insulation board #1089
3. High temperature hookup wire #7105
Auberins
1. PID #SYL-2352P
2. Thermocouple #TC-K-KLN 8 gauge/6 inch
3. Panel Mount connector #TCCON
4. SSR #40A SSR(Qty=2)
5. Heat Sink for 40A SSR (Square)(Qty=2)
6. High Amperage Main Switch 32A 440VAC
7. LED Indicator, 22 mm, 120/240V
8. Alarm lights/buzzers (Qty=2)
1sourcedist.com
1. Hoffman ASE12X12X6NK 12" x 12" x 6" Screw-Cover Pull Box
My control setup is like most others documented on the web using Auberins and BCS parts. The oven runs on 220VAC and the controls are housed in th Hoffman box ($19). Slo-blow fuses are used on the two legs of the 220VAC power and a single inline 1A fuse is used to supply power to the PID unit. The two heating elements are tied in series. All connection for the heating elements are done on the outside with stainless bolts. This includes the common connection point for the two heating elements. The insulation board from BCS holds the heating element connections and the thermocouple. I fabricated ventilated a safety cage to go over all of the connections. This was made from a sheet of expanded sheet metal screen and TIG tack welded together. The SSR switch line is routed through a micro switch on the door to a front panel light and then to the SSRs. I machined a piece of flat bar stock to be the mounting plate for the switch.
The SYL-2352P PID is fairly complex. It can hold 30 programming steps for controlling things like ramping, timed soaking, and alarm triggering. I got caught by an internally programmed alarm setting while going through the initial break-in procedure. The first alarm was set at 1000 deg F in
the overall setup as an overtemp alarm. Man it was noisy. I changed the setup to have it go off at 2000 deg F. The two PDF manuals are complete but a quick setup guide would have useful. I did some highlighting on the manual to easily find specific key sequences
for changing modes and programming setup.
