DIY Rotary Table
revwarguy
Mar 24, 2012
33
Does anyone know of plans or can point me to plans or blogs for a simple rotary table made from common items, like brake drums, wheel bearings, etc? I don't need positional accuracy, like a worm gear drive, I just need a table to clamp to that rotates smoothly around a point to mill round curves and holes.
I was once thinking 2 standard transmission flywheels would make a fixture that you are needing. the bottom fly wheel would be surface side down with no ring gear for a bolt down flange. The top flywheel would be face up with a seriese of tapped hole for hold down capabilitys. Im still pondering on the bearing between the 2. The ring gear on the upper flywheel can be mated with a crank handle to provide rotation.
