- Jul 18, 2017
- 405
Hi Guys,
So, I was browsing Craigslist (very dangerous since I already have too much stuff) when I saw an ad for a magnetic motor starter. I didn't know anything about these devices, so I did some research online. I wanted to know if I needed a magnetic motor starter. After 20 minutes of reading and not getting an answer, I thought I'd turn to you "gentlemen," and any "ladies" out there.
As most of you guys already know, I am a measly renter working out of a 1 car garage. Have 2 outlets on different circuits in my garage. My washer and dryer are on a 120v 20 amp circuit (I have a gas dryer), and my garage ceiling outlet (the apt mgmt installed it for my garage door opener and light) is, I am guessing, 15 amp ( It is "community" electricity so I don't pay for using this outlet.
With using my metalworking machines, I can run my Bijur micro droplet coolant system and the air compressor off the 15 amp ceiling outlet while the machine is on my 20 amp outlet.
Well, having limited power in my garage has forced me to be creative while still keeping safety in mind.
I wish I never encountered Bill Pentz's website at: http://billpentz.com/woodworking/cyclone/
After reading his blog on the horrors of woodworking dust, a 1 hp dust collector just wouldn't do for me anymore.
However, with my garage's current electricity situation, I can only run one machine at a time (which is fine since I would be by myself), and the dust collector would have to be run off the 15 amp "community" outlet. However, the 110v, 15 amp circuit won't work for motors greater than 1 hp.
Ok, I realize that this site is for machinists, not woodworkers. However, this is the only site that I am an active member of. Plus, I also plan on building a separate dust collector for when I am grinding metal. I already have a 12 inch aluminum impeller for it. Did I mention Overkill is my middle name?
Going back to the Bill Pentz blog, he mentioned how ineffective a 1 or 1.5 hp dust collector actually is at getting those nasty little particles.
How would I be able to have a larger hp dust collector if all I have is a 15 amp outlet?
Well, this is where I tell you my plan, and this is where you get to judge if I am either really smart or really stupid.
**Warning** --super long story with probably too much detail (Crap, maybe I should have put this warning at the beginning of the post)
First of all, my lathes and mills can use a VFD as a phase converter, along with a step up transformer to run 3 phase 220v motors with variable speed. I read online that lathes and mills can get away with not using a rotary phase converter and can use a VFD instead since they just need to the converter to start the motor.
With dust collectors, on the other hand, they have to use a rotary phase converter due to running at full load, and need the converter continuously.
So, for the dust collector, I picked up (at a deal) a Quick 220 voltage converter off Craigslist. This gadget will take 2 non-GFCI 20 amp 110v outlets, and will create a 220v outlet. Since I am a renter, I can't be rewiring the place, lol.
I looked at my circuit options, and decided to use the 20amp circuits for the garbage disposal and for the dining room outlets. All I have to do is drill a hole from my storage closet wall to the garage on the other side to run the heavy gauge power cord. Then, should I move out, just spackle the hole up.
I could have tried to use my 3000 watt step up transformer, but just felt the Quick 220 was better for the rotary phase converter.
Then, after researching what size rotary phase converter I needed (taking into consideration that the converter/slave motor should be at least 50% larger than the motor running the machinery), I bought a 5hp rotary phase converter for $135 off an ebay guy who makes these as well as "kits".
I then picked up, off of ebay, a 5hp Baldor motor for $50, plus $50.03 shipping, and a 2hp Baldor motor off craigslist for $60.
Fyi, I have gotten incredible motor buys off of Ebay when I use the "best offer" option with sellers who are liquidators. I once bought a 2hp Baldor Reliance vector motor, with encoder attached, for $95 plus free shipping.
I feel that it doesn't hurt to offer these guys super low offers since they are eager to move their inventory, and they have access to much cheaper shipping rates than the regular Joe guy selling a motor that he no longer uses.
So, I think I did ok. The total cost of the 5hp rotary phase converter and 2 motors cost just under $300.
I plan on hooking up the Quick 220 outlet cord into the 5hp rotary phase converter.
I bought the 2hp Baldor motor since I felt 2hp was sufficient for my dust collector. I then read conflicting info online in regards to whether there is motor power loss with rotary phase converters. The 2hp and 5hp motors are TEFC. However, if I am going to have power loss, I can use my spare 3hp Baldor motor, but it is not TEFC. 3hp would be the absolute largest motor I can use with this setup.
Ok, now that I told you all this info, I will return to my original question:
Do I need a magnetic motor starter?
Thanks in advance for any advice/feedback/schooling you may have for me
Susan
Susan
