VN Does Anyone Have The Dividing Head Gear Set?
Jason Annen
Jun 6, 2015
That is used for spiral milling? I would like to clone it, as I doubt I will ever find one. Message me if you have one and are interested in making some sort of deal.
Jason
It would be for the 10" VN dividing head. Pretty much any VN machine.
There is one on Ebay now.
Been there for months.
I think it's overpriced. But, it's there.
Do you have the 10inch swivel DH?
I've got most of the gear set.
I know that one of our HM members has the much coveted an rare total enclosure.
I've hoping to visit him this summer, and copy the hole pattern in order to make a banjo.
If I go completely nuts, I could make a sand cast copy and pour one out of aluminum.
Not sure if I want to work that hard.
Nor do I have permission to copy his cover.
Likely just as easy to pour multiples.
Daryl
MN
I've seen that set, is it the correct one since it has a 26 prefix? It only has 9 gears, and the one in the ACC brochure has 10 or 11.
If it's correct, I will grab it.
I think I have the correct 10" DH.
This is a Horizontal Swivel.
Mine is a Vertical Swivel.
I should double check, but l think it matches my vertical (I'm missing a few gears).
I've no idea what the horizontal takes.
Is the VN16 otherwise what you wanted (and I hoped) it would be?
Did you leave the spindle at the factory taper/collet?
Daryl
MN
I would assume the gears should be the same, however I am not sure.
The 16s is still sitting in the same spot, I have yet to power it up. I am planning on keeping it.
Jason
Hmmm.
I was hoping you would plan to unload it at a discounted price!.
If I get the banjo figure out, then I'll share the specs if you'd like.
Please expect this will take several months.....
Regardless, it is clearly on my priority list.
Daryl
MN
OK, so final thoughts on the eBay gears?
I'm still trying to locate an arbor support for that 16 too.
Jason
Top Bottom
