the Dremel gray polishing wheel and their green polishing compound? Thanks.
W whinot Registered Registered Joined Sep 4, 2022 Messages 6 Sep 4, 2022 #1 the Dremel gray polishing wheel and their green polishing compound? Thanks.
W whinot Registered Registered Joined Sep 4, 2022 Messages 6 Sep 7, 2022 #2 for all you wunderkinds of machining, Dremel says that the 424 polishing wheel's grit is 240 and their green polishing paste is 400 grit.
FOMOGO Active User H-M Lifetime Diamond Member Joined Sep 2, 2013 Messages 5,170 Sep 7, 2022 #3 I like mine with butter, salt, and pepper. Mike
pontiac428 John Newman H-M Lifetime Diamond Member Joined Apr 23, 2018 Messages 6,640 Sep 7, 2022 #4 The green chromium (VI) oxide compound is regarded as a grit of 2000 or finer.
