- Apr 28, 2014
- 3,590
Dogmeat™ denotes to me at least, "cobbled together" to fit a need.So what does "Dogmeat" mean? I searched on the web, and the meanings I found didn't seem to match what is being discussed here. Does it mean down and dirty, just something that it is not so elegant but still gets the job done? I am looking for a simple diamond grinder. I bought some Dremel diamond disks from Harbor Freight, and man those things go through the carbide. I see the allure; something like this should work really well, and no guards needed.
It starts here:
and then continues here on the board:
Engraver Power Hone - or carbide tool sharpening device
I gotta be honest, I couldn't figure out a better place to post this project. I've been making all the tools I need to try to learn how to engrave metal. I have everything done to the point that I may actually be able to put some deep scratches in steel soon. The last item I finished is...
www.hobby-machinist.com
Home Made, "Glendo Accu-finish" Show Me Yours
If you are going to scrape you need to put a radius on the carbide/HSS blades and they need to be lapped to a specified angle. How do you accomplish it?
Shop Made Diamond Tool Sharpener
I have been contemplating making a diamond tool sharpener to hone carbide lathe bits and carbide scraper blades. I would like a Glendo or an Accu-finish sharpening system, but wouldn't use it enough to justify it's expense. Even on the used market they are several hundred bucks if you are lucky...
amongst others...
