Well I finally had time this weekend to wire my vfd to my new PM-1340gt and do the initial break-in, which went perfectly thanks to all the information gathered here on this site from you good folks. The machine really is smooth. About the time I ordered the machine back in march I went ahead and picked up a Dorian BXA qctp and some assorted tooling. This morning I milled the t-nut and mounted the post. To my dismay, all the indexable cutters, which are 5/8" are about 1\8" below center line with the tool holder adjusted as high as it would go. The boring bar is even worse at 1/2" low. I'm assuming something has changed on the lathe to lower the top of the compound being that I've seen many of these 1340's with BXA tool posts mounted to them. Measuring from the top of the compound to center line of the bore I get 1.6875" which puts it more in the cxa range. 3/4" and 1" cutting tools just barely work, but I'll have to shim up the tool post to use the boring bar. Anybody else have this problem or am I just missing something?
