Am using a 3/4x60 degree double angle cutter HSS for doing serrations on a slide. They are not coming out as smooth and clean as i would like.Speed is about 300rpm and feeding fairly slow manually with about .003 cut.Does this sound to fast or slow and should I use coolant or would air do to keep clean
of chips.I am new at this and it is a junk slide i am practicing on with a Index 645 mill.
Thanks for any ideas
John:ideas:
John:ideas:
