Dovetail math?
Dinwoodie Cutlery Concepts
Mar 17, 2020
88
I could use some help calculating spacing for cutting precision dovetail pins. Basically if my spacing between 30 degree ( included ) dovetail centers is X and I rotate my vise 15 degrees to cut the pins on the opposing piece what would the x measurement be after rotating? Thanks.
Maybe this will help you? Scroll down to Measuring Dovetails.
Maybe I should rephrase the question. It doesn’t necessarily have to be a dovetail it could be holes. If I were to drill a series of holes 1” apart and then turn the piece 15 degrees how do I mathematically find the center of each hole from each other on a 15 degree angle.
