DP Mods
J Harp
May 5, 2011
6
OK: I've been urged to post so I'm going to try. If these pictures are too small I'm out of luck because the originals have been lost, I only have the small versions.
I bought this small drill press new for $39 and change some years back. The quill had way too much slop, here's how I fixed it. I've seen the question come up several times in various forums.
First I marked out, chain drilled, and punched out a hole on the bottom and back of the bore in the head casting. I cleaned up the opening with files and a mounted stone. This opening was to allow access for splitting the web at the backside of the bore, and to allow the casting to flex when a pinch bolt is tightened. Next I used that high tech sawing apparatus to split the casting from the hole I'd made clear through into the bore. Then I blocked the casting up as level as I could on my larger drill press and drilled through both sides of the casting for a 5/16 bolt.
After reassembling the quill into the head, I installed a cross bolt and snugged it up till the quill would move up and down freely, but without any side shake that I could feel when trying to wiggle it sideways.
Well Picasa is not cooperating, can't link to the pictures, was going to attach four photos. If a moderator wants to PM me, I can email the pictures and maybe he can add them.
Jim
Edit, Got some links, we'll see if they work.
https://lh4.googleusercontent.com/-FNnjYhc864A/TryLLEg7-nI/AAAAAAAABek/LsPJNSsUPmY/s800/IMG_0549.JPG
https://lh5.googleusercontent.com/-...AAAABeA/PYaAAtHHtrU/s800/IMG_0422 (Small).JPG
https://lh6.googleusercontent.com/-...AAAABeU/lfoGcS9vS1Q/s800/IMG_0426 (Small).JPG
https://lh4.googleusercontent.com/-...AAAABec/5OYD2kWZI-g/s800/IMG_0429 (Small).JPG
https://lh3.googleusercontent.com/-...AAAABd0/8rhsFXPbQ8M/s800/IMG_0430 (Small).JPG
Edit, I had image only, no link checked but it didn't work that way. Are there instructions for posting photos on this forum?
Jim, either email them to me, or give me the picasa url where they are.
tcwells AT hot mail . com
