[4]
Drill bit repair?
[3]
[10] Like what you see?
WesPete66
Oct 15, 2013
139
Likes
84
#1
I have a S&D drill bit of .875 diameter. It seems that the shank of it must be bent a bit. It doesn't matter how I chuck it up it wants to wobble at the tip, otherwise its a darn good tool. Is this something that can be remedied? how so?
Tinkertoy1941
H-M Platinum Supporter ($50)
May 10, 2012
65
Likes
75
#2
Grip the fluted end in your lathe chuck, check for run out of the cutting edges when it run true, turn the shank true with the flutes.
Use a center drill to put a center in the shank and use a live center
Turn the shank only till it cleans up or a common size your happy with!
Shank will be softer than the flute.
markba633csi
H-M Supporter - Gold Member
Apr 30, 2015
3,052
Likes
1,579
#3
Sometimes you can bend the shank and get a little improvement- or make it worse! LOL
Mark
Dave Smith
Mar 10, 2013
1,077
Likes
243
#4
I would find a pipe or bushing with an ID of .875---slip the bit in and lay it on a couple v blocks and rotate it till you can mark the high spot on the shaft--clamp the tube down good and tap the high spot with a hammer and recheck it---repeat this process as many times as you need till you get it straight --It takes a little time but gets easier each time you straighten a drill shaft---Dave
GoceKU
Brass
Jul 14, 2017
725
Likes
1,435
#5
In my opinion heat straightening is the only way, there is couple of good videos on youtube how to do it, but because of the time and heat involved may be cheaper just to buy a new drill.
[6]
[5] [7]
