Drill Press Quill Play
savarin
Aug 22, 2012
4,146
I need to get a new drill press and obviously the budget is very tight.
In searching the differing prices from ultra cheap to a respectable $1200 I found they all had side or fore/aft play in the quill.
How much play here is too much?
In my naivety I assumed the expensive ones would have zero play but such was not the case although it was less than the cheapest.
I haven't noticed this problem before. Drill presses usually ,more like always,have a slit in the housing where the hole for the quill is bored. Is there a nut at the bottom of the slit that you can tighten up a little to shrink the hole around the quill a bit?
Please reply after you've had a look.
If there is none,I'd start looking for an old drill press that DOES have the slit. I have not seen an older one that does not.
There doesnt appear to be a slit in any of the new ones.
If there is more play when the quill is extended than when fully retracted where does this indicate the wear is?
I find newer drill presses to be mostly garbage. Most older ones do have the slit to tighten up the quill, but some do not, ie atlas 42b.
I have about 10thou play on my atlas and don't have a problem with that, I always center punch and use good bits, so as long as it tracks right when you start you shouldn't have too much of a problem.
I looked at a few new ones just a few months ago and they all seemed worse then my 50+ year old one. If I do buy another it will be a good used one. They cost alot less too.
I had a new jet Dp, vs , laser, it was terrible, it did have the slot but adjustment did not help, the spindle was sloppy regardless , put that on Craigslist and it's gone . I then found a old craftsman cone head on Craig's list he wanted $75. For it ,the quill return was broken I told him I didn't want it, he was moving and didn't have room for it, he sold it to me for $50 and thru in two bench grinders .
I found the parts on eBay to fix it , it is 70 yrs old and has no slopp in spindle I like it !.
Get used to it.
Drill presses are NOT precision machines.
They are a heck-of-alot-better than hand holding an electric drill. But don't expect anything like a vertical mill's near-zero quill movement.
What size drill press do you have in mind?
