Our BP has VFD with single pulley, so we need back gear for good torque at slower speeds.
We found that slower speeds seem to work very well when drilling.
For hobby folks, there is no reason for too fast as it just damages the tool.
Do not measure RPM, more of a know from the look of it thing.
When using a drill press like tool and not using a portable device, you can actually drill to the capability of the tool.
Often with portable drill folks drill small hole then step up, fine but take too many steps.
The steps only need to be as large as the web.
We often drill 1/2 inch in one shot.
Slow RPM with good feed and oil.
Changing bits takes time...
If not sure what rpm to use, just start at some slower speed and see how it goes.
If it's too slow, it will cut just fine, and the chips curl out.
Too fast, and it cuts fine for a while, then not so much.
Sent from my SM-G781V using Tapatalk
