- Sep 15, 2017
- 321
Finished of my covid 19 drill sharpener today seen as im stuck at home hence the name .Got it reasonably well dialed in .can do from about 4mm upto 3/4 reduced shank drills .
Just set the cutting faces straight up and downHow do you initially set up the drill position? My work place has a darex m5 drill sharpener, as good as it is, it still a bit of a hit and miss devise depending to the helix angle of the drill needing to compensate with the drill seter.
I built it out of my head how ever have some rough measurments and angles that would get you buy to build onePretty cool.
