- Jun 10, 2019
- 534
What a good option for "drilling" small tapered holes? I need to make 2 steel indexing plates for my dividing head. The indexing holes have an included angle of about 4.84° (the plate is 0.272" thick and the index hole is 0.140" on one side, 0.117" on the other).
I will have 607 holes to drill....could use a 3rd axis right about now.
Searching around, it seems a tapered endmill may be best bet? The closest McMaster has is either 2° or 3° per side (4° or 6° included angle) and I'd have to get carbide (HSS not avail). McMaster link As an aside: would you use this to drill (they are center drilling) or would you drill a pilot first?
Another option I came across is to make a single-flute cutter; not sure I want to go down that road and I'd think it would need heat treating. And outside the box: I could probably make my own pin, thus a different (or no) angle other than a chamfer in the plates. I'd have to make 3 plates in that case though.
Suggestions welcome!
