[4]
DRO for smaller Logan.
[3]
[10] Like what you see?
mjhenks
Feb 5, 2014
196
Any recommendations for a basic DRO for a Logan 400 or 9B? I searched but did not find any existing threads.
What have you seen or used for the smaller Logan's or for that matter any smaller lathe. What did you use and why?
Thanks
T. J.
H-M Supporter - Gold Member
Oct 31, 2015
307
I haven't installed a DRO on my 10" Wards lathe yet, but I have done a small amount of research. There may be differences between the 9" and 10" Logan lathes that I'm not aware of, so take this for what it's worth.
To me, it seems like the biggest challenge to installing DRO's on these machines is the cross slide. Mounting a scale, especially a glass scale, on the right side of the cross slide would greatly compromise your ability to get the saddle close to the tailstock. Given the limited travel of the tailstock ram on these machines, this becomes a real problem. Mounting the scale on the left side of the cross slide might be an option, but you may have the same issue with not being able to get it close enough to the headstock. The significance of this issue may vary according to how far your chuck sticks out, or if you are using collets, etc. Also, with the scale mounted in this position, all of the chips will be falling directly on top of it, so guarding is especially important.
The best solution I have seen so far is to mount a magnetic scale directly over the cross slide lead screw and underneath the existing cover. The read head is mounted to the back end of the saddle. I first saw this on a YouTube video - I don't remember the author, but I'll see if I can find it.
The Blu-DRO setup with the magnetic scales gets a lot of good reviews: http://blu-dro.com/
That's about all I know. I'll be looking forward to hearing others' thoughts and experiences.
T. J.
Oct 31, 2015
307
Here's the video I referenced:
Briney Eye
Jun 16, 2016
141
Hey, thanks for the link to my video, T.J.! Mounting the scale over the cross slide screw has worked out great.
I'm trying to put together another video showing where I am with my electronic leadscrew. It's looking pretty good at this point. I'm trying to shave a few more microseconds off of an interrupt routine right now. Then maybe I can get the hardware mounted on the lathe this weekend. I've been saying that for several weekends now :).
T. J.
Oct 31, 2015
307
I'm looking forward to seeing that. And good to know that you still like your DRO setup.
[6]
[5] [7]
