- Nov 16, 2012
- 5,596
Hi Ray
I am sure you know, but get a 1micron scale for the X axis so you can use either Radius or Diam settings ( another point for discussion).
Secondly while most people seem to be going for cheap Chinese systems with glass scales, may I suggest you invest a little more in the newer miniature magnetic scales( Ditron, Electronica S1 or the even smaller EMC14). Magnetic scales are even easier to fit and are contamination resistant. Important for the X axis.
Finally my lathe was supplied with a cheap Chinese Display (Delos) but similar displays are available under many different brands. While it worked OK I found it a pain to use. Lots of Menu driven settings with many button presses. I threw it away and replaced it with a Easson 12B. What a pleasure to use. I am sure the Electronica models( expensive) that Dro Pros sell are just as good.
Good to see you entering the 22 Century
Ron
I don't know Ron... Sounded good at first but after looking at the prices of a magnetic scale setup, I'm thinking travel indicators aren't so bad.
One of the reasons I stayed away from a DRO in the first place was the additional crowding of space on the carriage.
---Gunna go climb under my 19th Century rock and go think some more about this.
Ray
