- Jun 26, 2018
- 1,733
Hey all, this should be easy for someone skilled at DRO/scale setup. My scales read fine, my EASSON DRO works fine, however, I came across an LCD DRO which I just prefer greatly over the ole' timey readout of the Easson. The resolution is set to .005 just as the Easson, they both are TTL square wave, set to linear scale (not rotary) Voltage output of both are the same (15v). I mean they are pretty straight forward...this is being used for 3 axis mill, and the DRO is also setup for..that's right, a 3 axis mill. Are there any other pertinent settings? When moving the table, the last # just jumps that increment its set to (.005 to .000 back and forth)
Thank guys and good night!
