John here, ex. Briggs & Stratton automatic standby dealer, factory trained. Also Honda and Subaru equipment dealer....
I'll make it easy for you. Get the Honda.
If you want to save a few bucks the Harbor Freight knockoffs seem to have a decent reputation but if you can afford the Honda....
Yes, ganged units is a good way to go for a couple of reasons. First, you have two generators so if one fails you have a backup. Second, smaller units are easier to move, and third if you need to loan one to a friend you still have one for your home.
Now, if you have natural gas and want an "easy" solution look into automatic standby units that hook to your home electrical and monitor the utility power so they'll kick in whenever needed. You don't need the biggest unit to run everything in your home but don't cheap out either and buy less than you need. These guys have the advantage of working if you're not there, my sales pitch was always to the wife because often they didn't have the confidence or strength to drag a portable out of the garage, hook it up, start it and keep adding fuel. They will "exercise" automatically every week and really take the worry out of outages for the most part since natural gas is rarely disrupted, can also run off a big propane "pig" for plenty of reserve fuel. One thing though, if you have a multi-day outage you really need to shut it down every day or so and check the oil unless you buy a big water cooled unit.
Back to portables, if you live in an area with boating you can often get "rec" fuel that doesn't have ethanol added. It will keep much longer and shouldn't mess up your carb.
Now me, I just have a couple of old Coleman units with big Tecumseh motors. I like them because although they are noisy I'm confident I can easily rebuild the carbs and get them running in an "end of the world" scenario. Also, they are left over from a big buy after that massive ice storm....
John
