- Nov 26, 2020
- 12
I picked up an early Rhodes Shaper last weekend. It appears to be built around 1903 and has a few interesting details. First, the foot is extended quite a bit under the table. It has a handle on the flywheel and a different ram design than some of the others I've seen. It does look pretty much identical to the 1903 ad I saw that showed it with a base that looked more like a lathe base. Unfortunately the base was nowhere to be found. Perhaps most curious is that the lettering on the casting side appears to have been placed by hand and has a couple of goofs. The wrong size R was used and some letters are spaced at bit too much and a little crooked.
