- Jan 10, 2019
- 1,042
I've had a lathe for around 20 years, and a mill for a couple, and it's a little embarrassing to say that I've never used HSS cutters, but I want to change that. I've looked at a few old tool grinders on Craigslist and want to ask:
1. How important is it to have the water drip reservoir? I get why water's needed (for cooling), but having it a permanent part of the machine just seems like it's going to rust up and/or leak.
2. Is there anything magic about buying a proper tool grinding machine versus just changing the wheels on a typical bench grinder? I mean, it's just a motor spinning a couple wheels. I'm assuming that the motors are probably 3600 rpm, and I understand that the wheels need to be well-balanced, but the balancing part is true regardless.
3. Summed up, is it better to buy an old used proper tool grinder, or is just getting the wheels and putting them on an appropriate speed motor virtually the same thing, and may actually be better because it's new parts vs an unknown older unit.
Thanks
Thanks
