Right now, if you are the kind of person who thinks 100k miles is just getting started, an EV might not be the best option. Not that I don't think they can do it, but we just don't have much data on longer term use. It might be great, but maybe not.
I can say that hybrids might be a good option there. There was a well known Prius taxi that had ~250k miles in some insane short time like 4 years.
For replacement cost, particularly of the battery, I plan to use rebuilt. Perhaps individually replacing cells or modules as needed. Much like fixing up an ICE engine vs buying a brand new one. Working on the battery should be done with caution. If you have experience with high power electricity, you can likely manage the risks. It's nothing really new, just not something car mechanics are used to. You can already buy parts or whole packs online.
Newer EVs are using heat pumps to help make heating more efficient. My Leaf is older and uses resistive heating. It works, but is less efficient. Hybrids use the coolant like normal gas cars. I just expect to have a bit lower range in the winter.
I'm in Northern Utah, and have a couple of winters on the leaf. It hasn't been a problem. The difference isn't huge, I drop maybe 10 miles of range. Sitting in stopped traffic for a long time could be an issue. I would avoid that when possible and ration heat use until I could get clear.
Really, everything has good and bad points. Pick your poison. I like how they drive, and lower cost for driving. Less junk in the air is nice too. I'm not a zealot about it though. What works for me might not work for you.
