Enco 13x40 Gear Head Lathe 510-2585
ocman
Apr 22, 2023
2
Hi,
I’m looking for a friend, for the Feed shaft for this lathe, part# 3017.
Can you point me in the right direction?
Serial# 39347
2008.12
Thanks!
Check with grizzly, They most likely have the part, It looks like a slightly up sized version of my 110-2075 12x36 lathe that Mr Mike gave me, Which is very similar to the Grizzly G4003
They may be the same shafts. If you can figure out whether Grizzly had a 1340 lathe similar to their G4003 you are in business, Just be ready for backorders because that is what I ran into when I tried to order parts for my 110-2075 Enco.
Here is a pic of an older Grizzly G4003, You may be able to have someone with the Grizzly lathe measure the feed rod for you, I am sure someone here has one they would measure for you.
