- Mar 2, 2013
- 895
enco 13x40 lathe vibrations and how to eliminate
I finally had the time and some money to make a 3x2 rect tubing base to mount my lathe to. Problem is, the tork from the motor startup vibrates the lathe, while the initial is far less after a few seconds i am still getting a slight vibration in the lathe. It appears (though i am not 100% sure) to be the connection of the lathe bed and the cabinets. My plan is to add rubber grommets where the motor attaches to the lathe to help isolate it, but i am looking for any other ideas that will reduce the vibrations to nothing.
On another matter, i bought a harbor freight magnetic base di stand and the dial indicator. After squaring the base and checking the front and rear ways with the dial indicator ridingnon the carriage, the front ways has a crown of about 5 thousandths. Is this an accurate way to check the ways, and if so, what is acceptable? If this is not an accesptable way, what should i do to test it?
thanks formthe help
rich
thanks formthe help
rich
