- Mar 29, 2023
- 5
First post for this forum but have been reading many of the other posts. Just bought an old Enco benchtop mill, model 105-1110. Overall it was in good shape. I was going to replace the drawbar which I saw was in poor shape prior to buying. Found the drawbar was slightly stuck in the spindle shaft but there was some movement with it. I had to lightly drive it out. The old drawbar was 7/16 inch diameter and the length was 16 1/2 inches. Could not find any that length so I ordered an 18 1/2 inch long bar and was going to cut it off to the needed length and rethread. Did not want to use a 2 inch spacer to make up for it being too long. New drawbar will not fit into the spindle drawbar shaft. Old drawbar measures .432 diameter and was tight. The new bar is exact at 7/16th inch or .438. Need some clearance so a 7/16 drill bit is not big enough. Was thinking about running a long 29/64th (.453) drill bit to enlarge the drawbar shaft. I would appreciate any other suggestions or comments. Planning to use a drill motor to open the shaft by about .020 inch. Thanks
