- Nov 27, 2012
- 7,862
When I got my first mini lathe I quickly learned that cutting bar stock with the strong arm method was not going to last long. I was going to pick a HF bandsaw until my buddy found me a used bandsaw locally an Enco 4x6 which is a RF-128, made in Tawain. It was practically never used, just sat in the back of some guys garage, still had the stock blade & was never adjusted.
Here it is when I picked it up 2 years ago. Was missing the saw table to be used vertically & the depth stop attachment.
Blade cover was damaged but a replacement from Enco was only $15.
Only thing I've done to it in the past couple of years was adjust blade alignment, change the oil, ditched the stock blade, installed a Fenner Power Twist belt on it, & just use the hell out of it.
For reference, my favorite blades to use are (they last a long time if used properly):
Titanium 6Al4V (which I cut the most): Lennox p/n 12897D2B51638, 6-10 variable tooth bi-metal, 0.025"
MSC p/n 82909524. Also available at Amazon. $25-$35.
General purpose: Irwin p/n 88508, 10-14 variable tooth bi-metal, 0.025" thickness.
Always on sale at Enco for $14.99, p/n 240-4930.
Here's what I use on the blade & in the gearbox.
Although I've been wanting a RF-712N or RF-712G clone from MSC for quite some time now, this little guy has been serving me well & has never let me down yet so I'll continue to use it for now until I really need the larger capacity.
Please feel free to share your 4x6 mods & ideas here if you'd like. Been thinking about a hydraulic downfeed mod too but I haven't looked into it much.
