- Oct 4, 2011
- 727
Since I got my surface grinder up and running I purchased the Enco "End Mill Grinding Fixture" http://www.use-enco.com/CGI/INSRIT?PARTPG=INLMKD&PMPXNO=949927&PMAKA=287-6840 With discount code and free shipping is was about $40. I already had a set of the 5C collets.
Over all the finish is good. The markings on the collar are laser etched into the part and hard to read when being used. I ended up marking the 4 positions for grinding a four flute end mill with a sharpie so I could see them.
Here it is on the grinder in the two positions for cutting the two angles for each flute. The thumb screw on the end locks the rotating collar into position. Its sometimes hard to get it to lock it into the right location. There is a small ball that sits in front of the thumb screw that should fall into the hole on the collar to indicate the position but I found you had to turn the collar back and forth to find the hole or it would lock in any position. There is no indicator line on the block to line up the collar marks. After a few end mills you get the feel of positioning it.
The block not only has the main two angles it is also tipped sightly to one side. This adds a clearance angle on the leading edge of he cutter. This also means you have to grind with the wheel on the flute closest to the operator. The first grind I made was on the flute on the back side and was all wrong. :banghead::banghead:
I was a little concerned with the small amount of metal touching the mag chuck when cutting the relief angle but so far it held just fine.
A big issue I had with the fixture is with the collet nut. This is the nut that tightens the 5C collets.
As shipped the nut uses two pins and a pin spanner to tighten. However, the nut when on the fixture is down in a hole. :nuts::nuts: You can remove the collar from the block and then tighten the collet but this makes lining up the end mill flutes very hard to do and I kept dropping the little alignment ball. I could not figure out how to do it. Maybe I am just missing something here.
So I cut a slot in the other side of the nut and made my own spanner wrench.
You can see the nut here down in the hole.
Now I just put the block on a flat surface "relatively flat", use a square to align the flutes, and then snug the nut down.
Here is about two hours of work. I got much faster as I went. A bad one takes about 5 min now. I got a box of these from .500" to 2.000" from a friend. He got them in an auction box lot with some stuff he wanted. Most of the flutes are really chewed up. He gave them to me so I could practice grinding. So far they all cut great as long as you don't try to cut to deep.
I am not going to put any pro sharpeners out of work but I am pleased so far with my results.
So far I have been very pleased with the tool.
Jeff
Jeff
