It's a great little printer - works well right out of the box. I recommend this video: Ender3 v2 neo setup as it goes over bed-leveling (yes, it has auto level, but you still want to level it manually before using the auto-level). Follow that startup procedure and it should "just work" for most stuff. That'll let you get your feet underneath you before you start breaking everything with new materials and custom slicer configurations... ;-).
I got the printer a couple days ago and did the leveling, etc. I printed the bunny that comes on the included sd card and it came out great. Now I'm printing my own drawings, from the 360 lessons. This should use up the last of the white PLA that came with the printer.
I'm pretty happy with the printer except the fans are awfully loud.
Kind of a nozzle purge - gets things flowing correctly before it starts on your print. If you watch it go down you'll see that it often starts out pretty thin (under-extruding) before everything hits the sweet spot and it's extruding a consistent width. (Other printers do the same thing.)
It's also pretty helpful when you switch colors and forget to purge the old color out of the nozzle.
except, on small prints the brim isn't quite long enough purge out all of the old color. being forgetful gets you some interest first layer color effects.
