Enlarging A Reamed Hole
FREDROSSE
Dec 28, 2014
10
When building a steam boiler, I had the tubesheets made, which use 1.250 diameter boiler tubes. The tubesheets came in with the reamed holes exactly 1.250, and I had trouble inserting the boiler tubes, the holes needed to be enlarged by a few thousandths. My only reamer was 1.250 also, so I put some 0.005 brass shim stock covering only about 1/2 the diameter of the reamer, and ran the reamer thru the 1.250 holes. Fortunately this worked very well, I was able to enlarge all 96 holes quickly, and then proceed with building the boiler.
Has anyone else made a reamer to cut a slightly larger hole with this method?
JimDawson
Global Moderator
Staff member
H-M Platinum Supporter
Feb 8, 2014
9,227
That is a cool idea, I've never tried it but you can't argue with success!
ARKnack
Dec 19, 2014
164
I would have thought that the shim stock would have been eaten up when reaming. Good solution.
brino
Confirmed Tool User
H-M Lifetime Diamond Member
Jan 2, 2014
4,172
Hey FREDROSSE,
Neat on-the-fly technique; I am glad it worked out for you.:encourage:
To be considered as a go-to technique, could you comment on two points:
What hole size did you end up with? (did it expand by 5 thou?, likely the reamer cut into the shims too...)
Did they remain round?
-brino
EmilioG
Jul 20, 2014
1,368
Cool. Glad it works. May come in handy in a pinch.
What RPM? Drill press or mill or?
I imagine that the reamer pushed against the shim while cutting, so it must have been slow yes?
How was the shim placed? above the cutting end? below?
Ed ke6bnl
Nov 20, 2014
590
do you need to put the tubes int he header and expand them to fit and seal, I have seen that in large boilers at work.
F
f350ca
Forum Guest
Register Today
I've done the same thing a few times, works like a charm.
Greg
Line_Bore
Oct 27, 2015
12
I've used that trick on smaller holes if I didn't have access to (or time to make) a barrel lap. A cigarette rolling paper works well.
Sent from my LG-H345 using Tapatalk
Vintagengineer
Feb 17, 2019
2
This is an old toolmakers trick, very well known in the UK. You can also grind a drill to cut oversize.
[7]
