ER-40 Collet Chuck for D1-5
Splat
Mar 10, 2012
1,242
I haven't had need for collets on my lathe until now. I like the abilities of ER-40 over 5C and have been looking for a collect chuck for D1-5 spindles and haven't found one yet. Anyone know of any or have maybe adapted something usable? I'd like to have thru-spindle ability. Thank you.
darkzero
Global Moderator
Staff member
H-M Lifetime Diamond Member
Nov 27, 2012
6,396
I haven't seen one for D1-5. You could always just get an ER-40 plate & mount it to a D1-5 backplate. That's what I did with my D1-4 & prefer it that way over the integrated style. I made mine so I can adjust runout if needed, loosen the screws, tap to adjust runout & tighten back up.
Splat
Mar 10, 2012
1,242
Thanks Will. That may be out of my league with the precisely needed drilling... but I do like a challenge! Any writeup on that one you did?
darkzero
Global Moderator
Staff member
Nov 27, 2012
6,396
No problem. Sorry, I didn't document the build on mine cause it was really simple. I used the bolt circle function on my DRO but really no precise drilling needed. Don't need a DRO or even need to calculate bolt circle.
I purchased a D1-4 backplate. Being a camlock backplate it's much easier to purchase one than making it from scratch. Simply mount on the spindle, face & turn down a step (registration boss) that will register on the ER-40 plate. Once that's done you can simply use a transfer punch to mark the mounting holes. Drill & tap wigh whatever you'd like. The mounting holes aren't critical as it's the register that takes care of the accuracy (asuming the ER plate is decently made).
The rest is optional, like turning down the diameter of the backplate to match the ER plate, etc. I made my registration a couple of thou smaller than the ER plate to leave room for adjusting runout. So if you choose to do the same, it will be even easier as you won't have to worry about a precision fit.
The hardest part of it all is making the money to buy the parts & cleaning up the cast iron mess after machining. :)
Splat
Mar 10, 2012
1,242
Veeery interesting..... but I remembered I had a few 5c draw tubes laying around so I'm going to make a 5c drawbar setup for my G4003G. Parts should be in tomorrow but I have to wait on my first boring bar and inserts to arrive. Of course, they'll be here AFTER the long holiday weekend but oh well. I've got many not as fun tasks around the house I'll need to do anyway.
jbolt
Dec 3, 2013
1,644
The trouble you will run into with a D1-5 spindle and an ER40 collet chuck is that all the affordable D1-5 back-plates I have found, the center hole is the same size as the minor diameter of the registration boss which is a little under 3-1/4". The largest ER40 collet chuck I have seen is 132mm (5-3/16"). When turning the back-plate to fit the chuck you can get into the cam-lock pins. I know from first hand experience turning down a South bend back-plate to adapt a 6" set-tru 3-jaw chuck that the pins are hard. It was doable with a carbide tool with no chip breaker to put up with the interrupted cut.
ddickey
H-M Supporter - Gold Member
Apr 21, 2016
2,563
I took my pins out and turned them down. Not the right way to do this so I will attempt to make my own back plate. Heading to the cities now to pick up steel.
darkzero
Global Moderator
Staff member
Nov 27, 2012
6,396
If you use the thick backplate that is the unmachined version for adjustable chucks (Set-Tru style) that issue should be avoided.
Here's a link to Grizzly's thick backplate (photo shows a D1-6).
http://www.grizzly.com/products/6-1-4-D1-5-Back-Plate-Thick/SB1398
Attached shows the specs on the thick backplates. Looks like the SB198 should work fine?
I'm not a big fan of Grizzly but I do like their SB branded backplates. Their quality is much better than the other unmachined backplates commonly available.
T Bredehoft
H-M Platinum Supporter
Dec 27, 2014
3,361
I can recommend the use of an ER40 collet system on a lathe. I put an ER40 on my lathe (MK2 Clausing, 6 by 20, MT2 spindle) about 3 weeks ago, haven't taken it off yet, I use it for everything. Yeah, round, up to 1". (no through the spindle use, but I don't use that anyway.) Anyway, for me its the way to go.
Jbar
Sep 24, 2014
25
Thanks for the link darkzero. I looked at that SouthBend back plate and it looks like the way to go. Do you or anyone else have recommend a certain ER-40 collet chuck to go with it? Not that it matters, but this is going on a Grizzly G-0709.
ddickey
Apr 21, 2016
2,563
I made my own d1-5 backplate. I bought the Tormach ER40 collet chuck. I tried using the Southbend plate but the registers was right on the camlock stud holes.
kd4gij
Feb 7, 2011
4,931
I don't get the attraction to ER40 collets on larger lathes 5C is much more versatile
Holescreek
Nov 10, 2013
837
kd4gij
Feb 7, 2011
4,931
I have used both for over 20 years. ER40 for tool holding and 5C for work holding. On lathes with a large enough spindle tube for a draw tube. There is just so much more options in the 5C line.
jdedmon91
Dec 29, 2017
600
I have a ER 32 on my lathe. I got a backplate from Grizzly and made an adapter plate to go between the backplate and the collet holder. The ER 40 is similar in the set up.
The ER 40 mount and backplate with an adaptor is the way I’d go. Just less to go wrong than the 5c system
keeena
Jun 10, 2019
77
I found this post while looking for info on D1-5 ER40 chuck. After hunting around (using DarkZero's good info as a starting point), I ended up finding that Shars makes both a back plate and compatible ER40 chuck. The back plate is new and not in their online catalog. I wanted to share the P/N in case it helps anyone out and because it's the only off-the-shelf solution that I found:
SKU 202-1029: ER40 Collet Chuck w/ Fine Adjust
SKU 202-7714: D1-5 Back Plate for ER40 Chuck
AdBlock Detected
I've Disabled AdBlock
