- Sep 29, 2017
- 2,253
I do a lot of excavator backhoe bushing and pins and I make them semi finished,harden them at the heat treatment company and then grind them to size with my toolpost grinder.
I do as much as I can to protect my lathe bed from the grinding swarf,but I wanted to protect my new bison 4jaw scroll chuck as well,especially when doing the ID. So I made a collet with BIG collet nut to clamp the bushing externally so I don't have to clamp it in the chuck. For the external grinding I have the expansion collets wich I already posted on.
The ID of the one side is 60mm and on the other side 55mm for two different size bushes. The thread is M70×1.5 and the collet nut is 85mm OD and made to use a C-spanner. It all works great and makes it very easy to change the bushes for grinding. Quick and easy,just the way I like it.
