Bought a set of collets and chuck for my lathe but have found the runout of chuck taper is 0.04mm and when you mount a collet with material the runout increases to 0.09mm so that's useless. my 3 jaw chuck is only 0.02mm.
Has anyone successfully ground the taper true, was thinking I could mount my air grinder on tool post clock up the angle and use the top slide to grind it.
Any thoughts. I have exceeded my refund on eBay due to Covid delays it testing my purchase.
