About 8 months ago I picked up a 6" EX-Cell-O Carbide Grinder from a local shop that was going out of business!
I currently don't have the need to grind or sharpen carbide, But for the price I couldn't pass it up!
I disassembled the grinder & worked a little bit at a time on cleaning everything up!
I finally got it all cleaned up repainted & reassembled.
Now that it's all cleaned up & reassembled I'm trying to figure out what to do with it?
I originally thought about just selling it! But after seeing how smoothly it runs, I'm thinking I'll probably just keep it & change the diamond & green silicon carbide wheels to ones designed for HSS.
The table on the righthand side has some type of micro adjusters on both sides of the wheel?
The dials are graduated in .0125" increments, .025" per revolution of the dial. There was probably some sort of fixture or jig that worked with the dial adjusters, But naturally that part was MIA.
I'm thinking that it would be fairly easy to make a angled jig or fixture that would ride in the miter slot & work for sharping drill bits.
Doug
Doug
