Extended tractor mirrors
Just for fun
Tim Young
Oct 7, 2020
2,128
I made a set of temporary mirrors that are about 9' wide for my tractor. I have a new 8.5' enclosed car trailer and we live on hill property. My truck is a Ford F350 crew cab dually. To get the trailer into its parking spot I use the tractor. I've had to have my wife shot me to get it into place. Now it should be a lot easier. I still need to finish up the mounting bolts and some painting. Since the main tubbing is galvanized I used silicone/ bronze to weld the mounting plates on.
The above. As a kid, my grandfather had a trailer park, with an old war surplus jeep. He had various diameter balls at the front and my job, at about 12, was to park and pull out the trailers. Life has not been quite as great since.
When I used to hang out at my buddies marina he had a trailer ball on the front of a fork lift for moving boat trailers around. It sure make life easy doing that way.
I have a couple of gooseneck trailers, seeing around the horse trailer is not easy, putting it in front on the loader doesn't really help seeing around it, unless you drive like a taildragger taxiing on the ground (lots of swerving for lack of seeing over the nose). And if you move the trailer any distance you end up going backwards and looking over your shoulder, which can leave you with a sore neck/back.
I use a three point hitch mounted 2 5/16 ball, which can handle a bit more weight than the ~3000 lbs the loader can take. That gets to be critical as the flatbed when loaded with hay can be over 10 tons total, and with that much weight you need at least 2 tons on the hitch.
