- Sep 7, 2019
- Location
- Pittsburgh, PA
I was thinking drill rod just because it's smooth and well round. Also since it's harder than mild steel it should be a little more resistant to bending.
Also, in the interest of delving even deeper into uncharted territory, I'm thinking of doing a recovery baffle. What do you think of this design...
I drew it up a detail in OpenRocket. The aft section is the bulkhead already installed in my rocket. It's got eight 1/2" holes radially around the circumference. The forward bulkhead is a centering ring with only one hole in the center to which is glued a heavy paper tube. The gap from the aft bulkhead to the center tube is 1/4".
My thinking is that the gases would be forced to swirl around in a chamber before finding the path through the tube and out to the nose cone.
Any opinions?
If this doesn't seem good I'll probably make some kind of chute protector. I'm trying to get away from waddings.
Any opinions?
