I need to face one end of a 6061 aluminum rod that's 1 5/8" diameter by 12" long. Doesn't have to be beautiful, I just need to get it to sit square on an aluminum plate.
It's been about four years since I've used my lathe (Grizzly G0516, 10x22 Sieg C6 equivalent). If I go that route, first thing I'm wondering is whether a solid rod of that length will be safe in the lathe's three-jaw chuck. If it seems ok, then I need a little remedial refresh on setup. In particular, cutting tool setup -- I have some indexables and the lathe has a basic QCTP. Do I keep the tool holder 90 degrees to the workpiece and extend enough of the tool to cover the 13/16" radius? Or expose less and put the holder at an angle? Also, wondering about optimal speed.
The other thought that occurred to me would be doing it on the mill. Any reason that'd be a bad idea?
Thanks for any thoughts.
