I am using, and am quite satisfied with, a static phase converter, which is what the DPS appears to be. (Mine was even cheaper) On startup, the third leg is provided with a short burst of power from the capacitors which starts the motor spinning. If the machine has powered controls (relays, etc), they must be wired to one of the two hot legs, not the third (wild) leg. Your problem with the DPS could simply be that it is connected to your machine incorrectly. A picture of the machine controls might help.
