I bought a J head Bridge port clone mill in a very bad shape, scrap metal price a while back. It was in such a bad shape that I was a bit embarrassed to share, until I can bring it back to life. However, I need help. There are various gears in the auto down feed assembly that are bad. So far, the input gears are bad, here's a listing that has the input shaft with 3 straight spur gears:
https://www.ebay.com/itm/Bridgeport...e-worm-gear-cradle-2190059-M1318/173988385261
Then, the cluster gear is also bad , here's a listing:
https://www.ebay.com/itm/Bridgeport...tomatic-Feed-Shaft-CNC-Mill-Tool/323966092106
So, I am thinking of making the gears, or bronze braze and cut it out, versus buying the parts, with buying as a last option, and saving the money for things like dividing head, which I would need in the future anyway.
What do you think? Will it be possible to take a picture of a good tooth, zoom it large and some how match with various profile of teeth (from generated calculator for example) and figuring out various thing like pressure angle, diametral pitch, etc. Or maybe since it's a bridge port clone,they're well known values (I couldn't find it anywhere). I even wonder if the 3 gears (of the cluster gears) has a same specs such as diametral pitch and pressure angle.
