- Jan 30, 2012
- 20
My main mill is a square column RF-45 type. I'd love to have a Bridgy, but my workshop is packed, (I'm both a pack rat and a slob).
I scored a Kurt Bridgeport automatic power drawbar at an auction for $135 . It's made to bolt directly onto the top of the BP head. The problem is on the SQ col mills, the spindle sticks out over 2" from the top of the head, while on the BP, it is inside the head. The drawbar that came with it was also several inches too long. to fix that, I drilled out the retaining pin, then pulled the pressed on head off the bar. The unthreaded end was cut down to length, and then machined for a solid press fit, then re-pinned.
The only way to make it work given the way the draw bar sticks out was to build a riser for it.
Here is the design I came up with.
Here is the partially completed riser, still missing the feet.
And finally, mounted to the mill head. Unfortunately, the cover to the unit didn't come with it. I saw one on ebay, but with shipping, it would have come to over $30. Eventually, I'll get around to making one.
Regards,Eric Sanders
http://www.compufoil.com
