I have gotten a Saylor Beall 2 stage air compressor that had a knock while running. Needless to say this compressor was not well maintained. What I found on disassembly is in the attached photos. The High Pressure Piston wrist pin has worn its way through the wrist pin bushing and has worn into the connecting rod.
I have measured the wear area and it is 10 thousands deep into the connecting rod. The Wrist pin bushing is .950 OD and .750 ID the bushing is pretty thick at .125.
I can still get a new wrist pin and bushing, but the cast iron connecting rod is no longer available new and I have not been able to find a NOS or a used one so far.
So my thoughts for this is
1. Do nothing and install a new bushing and move on. Not my best option but I will not be using this compressor in a commercial application.
2. Use brass shim stock to fill the void between the bushing and connecting rod. If I can get it to stay in place while installing the wrist pin.
3 Use JB Weld or something similar to fill the .010 indention. Don't know if it would bond well to such a small area and feathered out so thin. Its also in the area of the connecting rod that gets the most pressure during the compression part of the stroke so not even sure it would work.
Since I don't have the tooling needed to ream out the .950 connecting rod, I am trying not to braze up the indention.
Any ideas or thoughts on this will be appreciated.
