Hi All,
I recently picked this engine up on fleabay for a steal!
It seems to be in pretty good condition, jut needs a good cleaning and polish.
I am having a hell of a time trying to get it to run!
The original spring steel valve(?) did not cover the whole inlet port so i made a new one that fits a lot better and actually gives the engine
a bit of compression.
It has a graphite piston.
The only ball bearing is the one that runs on the cam.
I am wondering if the return springs tension is too high.
It takes a lot to spin it over.
I have tried lots of different flames, sizes and positions but no luck.
I have also read through all the builds here and tried a few of the mentioned fixes to no avail...
Any help would be greatly appreciated!!
My fingers are aching from flicking over the flywheel for the past 2 hours....
Andrew
Andrew
