- Apr 16, 2019
- 745
My first garage (about 30 years ago ) I had the masons power trowel it . Then after 30 days used a Benjamin Moore 1 part epoxy , the instructions had you thin the first coat to get into the pores the 2 full coats . The problems with that - "hot tire pick-up" pretty much from the beginning , then years later for the road salts and brime but those were only under where the cars sat everywhere else looked pretty good though like what was said you have to be careful welding and burning because it will burn into it . Depends where you live it does condensate bad on those winter days that go from cold and dry to warm and moist . I've had to squeegee and mop it dry just so we wouldn't fall !! I didn't have any machines at that house in the garage . The house we moved last year the garage was about 50 years old and had a very dirty , hand finished , crack , floor after cleaning and prepping used a Behr primer & latex one coat epoxy , this doesn't seem like it will hold up as well , spots that brakeclean hit peeled pretty quick and now have a mill and lathes but so far having mats in front of the machines seem to help . Because most of what I do is repairing I like a bright floor and if I had a separate area for machines I would still paint the floor , if there was a welding area I would just seal it with a clear only if it was power troweled .
