I have just started with milling on my combo machine. Trying to clean a bit a piece of structural steel (I know is one of worst materials ever, but I have nothing else easily available), not knowing jack about the ideal shape I've just ground some back relief in an 8mm square HSS.
The result is less than perfect, I used a slow power feed, but something must have moved at some point
Probably it has nothing to do with the above but it bothers me that I can see the top of the spindle wobble a bit, in fact I measured as per topic title, where the picture is taken. In another topic I had reported about a slightly better TiR measured at the collet chuck and was told that the machine is useable anyway.
This is a 550W machine with a MT2 spindle. Any chance that the bearings can be adjusted? Replacing them could improve the situation?
