I use that same setup and coolant on my surface grinder. It works fine, just make sure you adjust it (or any 'mister') so it is more sputtering than misting. Even then, and with a safe coolant like the Kool Mist, it is important to wear a dust mask at the bare minimum. If I don't, I start getting a sore throat, goes away when I use protection.I just ordered something like that and Kool mist #77. I am a bit excited how it turns out. I also wonder if the mist is safe to breath.
I just went out and unscrewed the nozzle. Yes, there is a small hose inside the loc-line.Bob, do you know if it has a tube running through the loc-line to the nozzle?
Sent from my SM-S757BL using Tapatalk
