A bit unclear as to which specific display and type of scales you are interested in. Multiple people have purchased form Machine DRO in the UK and they air ship there DRO's arrive in about 1 week. I have also bought magnetic scales from SRA, which are the the same as sold form M-DRO (UK). I also have done installs and own the EL-700 from DRO Pros. They are very good but also expensive and the EL-700 is a touch screen which is a bit of a PTA with greasy/wet fingers. I have installed all these as well as other brands, my preference on the lathe is more of a simpler DRO, but I do find that the newer graphical color displays are much easier to read and less effected by reflections/sunlight shining on the display then the LED displays. Quite a few people have gone with the ES=12B with magnetic scales from Machine DRO in the UK, they basically will put together a package that fits your needs as to lengths and resolutions. You want a 1 uM scale on the cross slide and 5 uM is fine for the bed/long axis. I use the 3 channel version and have the 3rd axis on the tailstock which I really like. SRA is more expensive, also worth looking at is the Aikron DRO, there are a few people that have installed them and seem to like them. I would not recommend the Ditron with magnetic scales, a lot have people have reported poor resolution/accuracy with their magnetic scales.
I should add that you are better off making your own mounting brackets.
3 Axis Easson ES-12B LCD graphic digital readout package with two magnetic encoders. The encoders offer a very compact profile size and can be cut to length to custom fit the machine being installed. The package is suitable for mills up to Bridgeport 42" sized machines or 30" between centre...
www.machine-dro.co.uk
Shop LCD DRO from Aikron! Our A30 LCD DRO can be applied to the milling machine, lathe, and grinder,2 and 3-axis DRO kits are also available!
www.aikrondro.com
