g0602 dial help
U
umahunter
Forum Guest
Register Today
Ok maybe I'm doing something wrong so I thought I'd ask my compound dial show in the pic doesn't move when I turn the handle it will start to move a lil then I can just spin the handle and nothing is there some way I'm supposed to engage it I'm not aware of ???? Help this newb
It may need another shim to space it out from the housing. It also could have some chips in the works, or a burr on the dial or housing. I would pull it off and clean things up, and maybe do a little cleanup with a file if needed.
I sounds like the key way is broken or the cross feed nut stripped or the hardware fell out.
You need to tighten the knurled ring to hold it.
You sure it dont have a set screw in the center of the wheel nut? Mine have a screw there to lock it. I hated it so I drilled and tapped the ring through the center of the 0 and added a 1/4 bolt that I can tighten by hand
Many of the smaller size import lathes have a piece of spring steel or an actual spring to give it friction. Take the handwheel off & slide the dial off. There should be a groove. In that groove would be a bent piece of steel in a v shape. It may have broke or no longer has tension. You can easily make a replacement out of steel strapping.
If you do not figure it out just say tje word and i will take the dial if my lathe and see what it has
Thanks guy I will check it out hopefully later tonight or tomorrow I had pulled it once and everything seemed fine so I put it back together and it spun fine for a couple revolutions the kinda got slower like it was slipping then just stopped spinning
No, the knurled ring is part of the dial. Its purpose is to allow rotating the dial to set zero or some other number while you hold the crank. Then, it should rotate with the crank, being driven by friction.
