- Jun 10, 2019
- 534
I just bought a lightly used G4003G lathe and had a question about behavior of the leadscrew. When I was in the lowest TPI setting (4TPI, tumbler in A-1) I was able to easily stop the carriage by putting minor pressure on the hand wheel. This caused a bit of a grinding noise. The noise would stop and carriage continued once pressure was released. I was able to do this twice when I was testing the lathe before I bought it. I haven't had a chance to look more closely yet (just bought/moved 2 days ago, haven't powered up here). Tumbler and change gears look perfectly OK.
I'm pretty sure the lead screw stopped during this test so it wasn't a half-nut engagement problem. I'm pretty sure this model doesn't have a clutch. I also was not able to produce this at higher/high TPI, which seems to make sense because the higher TPI gearing would mean I'd have less leverage over the gearbox. But this could have been a fluke... When working the lathe by hand, I did notice that its possible to get the leadscrew/feed rod selector in a near-neutral position but still have a slight engagement on the leadscrew gear. This is the only thing I can thing of that might have caused the issue...possibly not fully engaged and I was just able to slip/grind gears because they were barely meshed.
Anyway - just hunting for ideas before I have a chance to hook it up and play.
