I'm slowly getting together what I need for my G4003G lathe and am looking at oils they recommend. For the headstock Mobil DTE Light is recommended. The only place locally that has it in 1-gallon jugs is McMaster. However, I found they also list another oil that is very similar to the DTE Light, and $9 cheaper. Mcmaster #3025K25. For the gear box and apron they recommend Mobil Vactra #2, which McMaster also has a similar oil, though with slightly lower Saybolt number, with their stock # 1017K11.
I was wondering if anyone is using these McMaster oils, or if not, what other oils are you using? Thanks.
